two = Integer.parseInt(priceperlitrestring.substring(2,3));
If an if statement has more than one line within it's block, you should encapsulate with {}. So for example:
Code:
if (priceperlitrestring.substring(1,2)==".")
one = Integer.parseInt(priceperlitrestring.substring(0,1));
three = Integer.parseInt(priceperlitrestring.substring(3,4));
four = 0;
should read:
Code:
if (priceperlitrestring.substring(1,2)==".") {
four = 0;
Should do, yeah. You'd pass in 0 as the digit if you wanted the digit immediately to the left of the decimal point, -2 if you wanted the digit two places to the right, 4 if you wanted the digit 4 places to the left, and so on.
The problem is I won't know at the time whether there will be 3 or 6 digits in a number, so if say digit 5 is set to -2 and there isn't 2 digits after the decimal point won't that result in an exception?
just convert the double to a string then do String.charAt(), then check if it is a "." and if it is don't parse in into an Integer. this can be done in a while loop so you won't require those 3 if statements.
Nope, it'll just return 0. You could pass -43 or 76 or something similar in and it'd just return 0, as you'd expect it to. There's nothing in there that could actually produce an error, so you're OK.
It would make better sense for the sevensegmentdisplay (which for semantics sake should be SevenSegmentDisplay) to accept a float and the conversion occur within the object.
