Java: Hashtables and checking a element is less than value of 40
7 Dec 2007
Derbyshire, Tibshelf
For an assignment, one of the tasks is to display someone with a grade less than 40. So far i've got this:
Enumeration enumName = NameGrade.keys() ;
Enumeration enumGrade = NameGrade.elements();
txtOutput.setText("");
while ( enumGrade.hasMoreElements() ){
currently converting object to string, then to integer and checking if its less than 40
if ( Integer.parseInt((String)enumGrade.nextElement() ) < 40){
txtOutput.append("Name: " + enumName.nextElement() + " - " + enumGrade.nextElement() + "%\n" );
InputName.setText("");
InputGrade.setText("");
}else{
Just isnt working :/ I input 2 people, one with a grade under and one with over 40 then click the button. At first it was displaying one person but with a different grade ;o then I changed it and it errors out showing nothing at all... I can imagine the error is blindingly obvious if anyone good with Java could check it out :) Hope theres enough information there..
Thanks so much, you would be saving my neck as Im really not getting any of this :P
thank you so much, it works properly! I get a load of errors though, even though the program still runs and seems to be doing what it needs to do. the first two of the errors are:
Exception in thread "AWT-EventQueue-0" java.util.NoSuchElementException: Hashtable Enumerator
at java.util.Hashtable$Enumerator.nextElement(Hashtable.java:1021)
Im fine to leave this lol but.. what is causing that do you think? cause they were my main concern last time, even though it wasnt showing stuff correctly too :D Thanks sooooo much
