JAVA help?
28 Nov 2005
I need a bit of pointer, i have to make something in java where you enter 2 words but the whole thing has to be below 37characters...and between the two words the extra characters are used up by dots?
Im a bit stuck :(
String.split() and String.substring()
Quick example to get you started.
Code:
public String shortenString(String myString)
    if ((len = myString.length()) > 37)
        return myString.substring(0, 34) + "..." + myString.substring(len - 3, len);
    else
        return myString;
use lastIndexOf(" ") and a few sums to work out words.
