- 21 May 2003
Hi. I'm trying to make a program which has two arguments. the first is a flag (-u, -l, or -t) and the second is a string. the flag says wether to make it upper case, lower case, or title case.
Here's the code i've done so far:
class Case
public static void main (String[] args)
String tag;
String text;
Case program = new Case();
if (args.length != 2)
System.err.println ("Invalid");
System.exit(1);
tag = args[0];
text = args[1];
if(tag.equals("-u"))
System.out.println(text.toUpperCase());
else if(tag.equals("-l"))
System.out.println(text.toLowerCase());
else if(tag.equals("-t"))
program.titlecase(text);
else
System.exit(1);
void titlecase (String text)
The problem is, when i send the text to title case, it's still as a string. to make it title case, i need to read every character, and make every character after a white space a capital.
I was thinking to make it an array but i don't know how to convert from a string to an array. Or maybe i could make it an array from the very beginning and use loops to capitalise and lowerise(!). but how?
EDIT: for osme reason *** code isn't keeping its indentation.
class Case
String tag;
String text;
System.exit(1);
tag = args[0];
text = args[1];
else
System.exit(1);
