java <identifier> expected
19 Jul 2006
Im trying to build up a number testing system that takes a number array and goes through to se if th e number is above 0
the if statement is causing a problem and i dunno why
Code:
 public boolean isValidnumber()
      boolean numberTest;
      numberTest = true;
      for (int i =0;i<number.length;i++)
      if((number.[i])<0)  // this is causing a <identifier> expected error
        numberTest = false;
      return numberTest;
Code:
if([COLOR="Red"](number.[i])[/COLOR]<0)
should be:
Code:
if([COLOR="Red"]number[i][/COLOR]<0)
IF the purpose of your code is to check weather a number in an array of integers is less than zero (negative) then there is another way of writing it.
Code:
	for (int i : number)
		if (i < 0)
			return false;
return true;
