java.io.NotSerializableException
Caporegime
12 Mar 2004
England
Code:
public class Implementation extends java.rmi.server.UnicastRemoteObject implements VotingInterface {
	private Election[] electionList = new Election[99];
	private int numberOfElections = 0;
	public Implementation() throws java.rmi.RemoteException {
		super();
	public int createElection(String electionName, String[] candidates) throws java.rmi.RemoteException {
		numberOfElections += 1;
		electionList[numberOfElections] = new Election(candidates, electionName, numberOfElections);
		return numberOfElections;
Code:
public class Election {
	private Candidate[] candidates;
	private String electionName;
	private int id;
	private boolean closed;
	public Election(String[] candidates, String electionName, int id) {
		this.electionName = electionName;
		this.id = id;
		this.candidates = new Candidate[candidates.length];
		for (int i = 0; i < candidates.length; i++) {
			this.candidates[i] = new Candidate(candidates[i]);
	public Candidate[] getResults() {
		return candidates;
	public void closeElection() {
		closed = true;
	public void vote(int id) {
		if (closed == false) {
Code:
public class Candidate {
	private int numberOfVotes;
	private String name;
	public Candidate(String name) {
		this.name = name;
	public int getVotes() {
		return numberOfVotes;
	public void vote() {
		numberOfVotes += 1;
Help me understand this one guys. I understand that java can't serialize this class, but why is it trying to? The error occurs when I call the createElection method.
Say what? :p
Implementing the serializable interface in candidate fixes the problem but can you please explain what exactly is going on in this situation?
Why did you extend from java.rmi.server.UnicastRemoteObject? What I'm getting at is if you did this on purpose you should already know why you need to serialize remote objects
