[19:31:41] [SEVERE] addOverride(/terrain.png,/Zeppelin/back.png,187). 32 left.
[19:31:41] [SEVERE] addOverride(/terrain.png,/Zeppelin/top.png,188). 31 left.
[19:31:41] [SEVERE] addOverride(/terrain.png,/Zeppelin/compass.png,189). 30 left.
[19:31:41] [SEVERE] addOverride(/gui/items.png,/Zeppelin/radio.png,176). 61 left.
[19:31:41] [SEVERE] Rotation data loaded so far: 0
[19:31:41] [SEVERE] Starting reading rotation data from "\technicssp\config\MetaRotation\Vanilla.meta"
[19:31:41] [SEVERE] Finished reading rotation data from "\technicssp\config\MetaRotation\Vanilla.meta"
[19:31:41] [SEVERE] Rotation data loaded so far: 290
[19:31:41] [SEVERE] Mod Loaded: "mod_Zeppelin 1.1.0.0.25"
[19:31:41] [SEVERE] Mod Loaded: "mod_NetherOres 1.1.0R1.1.2"
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreCopper, id=249 meta=0
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherCoal, id=135 meta=0
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherCopper, id=135 meta=6
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherDiamond, id=135 meta=1
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherGold, id=135 meta=2
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherIron, id=135 meta=3
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherLapis, id=135 meta=4
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherRedstone, id=135 meta=5
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreNetherTin, id=135 meta=7
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreTin, id=248 meta=0
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreUranium, id=247 meta=0
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: woodRubber, id=243 meta=0
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftAutomation 3.3.1"
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftBuildcraft 3.3.1"
[19:31:41] [SEVERE] Railcraft Core Module: Bronze detected, adding alternative minecart recipe: ingotBronze, id=30,246
[19:31:41] [SEVERE] Railcraft Core Module: Bronze detected, adding alternative minecart recipe: ingotBronze, id=5,261
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftCore 3.3.1"
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftExtras 3.3.1"
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftFactory 3.3.1"
[19:31:41] [SEVERE] Railcraft IC2 Module: Tin detected, adding Energy Detector recipe: id=30,247
[19:31:41] [SEVERE] Railcraft IC2 Module: Tin detected, adding Energy Detector recipe: id=5,260
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftIC2 3.3.1"
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftInfrastructure 3.3.1"
[19:31:41] [SEVERE] Railcraft Factory Module: Bronze detected, adding alternative recipes: ingotBronze, id=30,246
[19:31:41] [SEVERE] Railcraft Factory Module: Bronze detected, adding alternative recipes: ingotBronze, id=5,261
[19:31:41] [SEVERE] Railcraft Factory Module: Refined Iron detected, adding alternative recipes: ingotRefinedIron, id=30,249
[19:31:41] [SEVERE] Mod Loaded: "mod_RailcraftRails 3.3.1"
[19:31:41] [SEVERE] Mod Loaded: "mod_ThaumCraft 1.2.5"
[19:31:41] [SEVERE] Mod Loaded: "mod_treecapitator 1.1"
[19:31:41] [SEVERE] Mod Loaded: "Balkon's WeaponMod 1.1.0 v8.4.0 SMP Edition"
[19:31:41] [SEVERE] Mod Loaded: "WirelessRedstone 1.5"
[19:31:41] [SEVERE] Railcraft IC2 Module: Tin detected, adding Energy Detector recipe: id=1,257
[19:31:41] [SEVERE] (MAtmos : INFO) ExpansionLoader fetched interactions_extras.xrl.
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreSilver, id=140 meta=3
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreTin, id=140 meta=4
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreCopper, id=140 meta=5
[19:31:41] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: woodRubber, id=143 meta=0
[19:31:41] [SEVERE] (MAtmos : INFO) ExpansionLoader fetched earthlies_database.xrl.
[19:31:41] [SEVERE] Starting BuildCraft 3.1.3
[19:31:41] [SEVERE] Copyright (c) SpaceToad, 2011
[19:31:41] [SEVERE]
http://www.mod-buildcraft.com
[19:31:41] [SEVERE] blockABOPipeID set to 200
[19:31:41] [SEVERE] pipeLiquidsValveID set to 10200
[19:31:41] [SEVERE] pipeLiquidsGoldenIronID set to 10201
[19:31:41] [SEVERE] pipeLiquidsBalanceID set to 10203
[19:31:41] [SEVERE] pipeLiquidsDiamondID set to 10204
[19:31:41] [SEVERE] pipeItemsRoundRobinID set to 10300
[19:31:41] [SEVERE] pipeItemsCompactorID set to 10301
[19:31:41] [SEVERE] pipeItemsInsertionID set to 10302
[19:31:41] [SEVERE] pipeItemsExtractionID set to 10303
[19:31:41] [SEVERE] pipeItemsBounceID set to 10304
[19:31:41] [SEVERE] pipeItemsCrossoverID set to 10305
[19:31:41] [SEVERE] pipePowerSwitchID set to 10400
[19:31:41] [SEVERE] triggerEngineControlID set to 128
[19:31:41] [SEVERE] (MAtmos : INFO) ExpansionLoader fetched interactions_environments.xrl.
[19:31:41] [SEVERE] (MAtmos : INFO) ExpansionLoader Limbo is now empty.
[19:31:42] [SEVERE] Additional pipes detected, adding compatibility
[19:31:42] [SEVERE] LogisticsPipes: got texture id 159 for supplier texture
[19:31:42] [SEVERE] RegisterGUI error: inventoryType already registered.
[19:31:42] [SEVERE] Using buildcraft.energy.PneumaticPowerFramework as framework.
[19:31:42] [SEVERE] Registering ore apatite.
[19:31:42] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreApatite, id=198 meta=0
[19:31:42] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreCopper, id=198 meta=1
[19:31:42] [SEVERE] Railcraft Automation Module: Ore Detected, adding to blocks Tunnel Bore can mine: oreTin, id=198 meta=2
[19:31:42] [SEVERE] Skipped plugin class forestry.plugins.PluginTwilightForest because preconditions were not met.
[19:31:42] [SEVERE] Initialized
[19:31:45] [SEVERE] (MAtmos : INFO) SoundCommunicator loaded (after 4.415 s.).
[19:31:45] [SEVERE] (MAtmos : INFO) Bypassing Resource Reloader. This may cause issues.
[19:31:45] [SEVERE] (MAtmos : INFO) ResourceReloader finished (after 4.513 s.).
[19:31:45] [SEVERE] (MAtmos : INFO) Ready.
[19:31:45] [SEVERE] (MAtmos : INFO) ExpansionLoader signaled. Currently has 3 expansions and 0 in limbo.
[19:31:45] [SEVERE] (MAtmos : INFO) Expansion interactions_environments.xrl loaded.
[19:31:47] [SEVERE] (MAtmos : INFO) Expansion earthlies_database.xrl loaded.
[19:31:47] [SEVERE] (MAtmos : INFO) Expansion interactions_extras.xrl loaded.
[19:31:47] [SEVERE] (MAtmos : INFO) ExpansionLoader Loading and Limbo are now empty.
[19:31:52] [SEVERE] (MAtmos : INFO) Update version found: 11
[19:31:52] [SEVERE] Railcraft Buildcraft Module 3.3.1: Buildcraft Detected, creating Tank Cart and Liquid Loader recipes.
[19:31:52] [SEVERE] Railcraft IC2 Module 3.3.1: IC2 Detected, creating MFE Cart and Energy Loader recipes.
[19:31:52] [SEVERE] EquivalentExchange has loaded RP2 ores, plants, trees and stone blocks.
[20:56:05] [SEVERE] ------------------------------------------
[20:56:05] [SEVERE] Launcher is starting....
[20:56:05] [SEVERE] Launcher Build: '1.0.1.3'
[20:56:05] [SEVERE] Allocated 910.25 Mb of RAM
[20:56:05] [SEVERE] Java VM: '1.6.0_33-b03'
[20:56:05] [SEVERE] OS Version: '6.1'
[20:56:05] [SEVERE] Is 64-bit: 'true'
[20:56:05] [SEVERE] [Info] Downloading 'mirrors.yml' from '
http://mirror.technicpack.net/Technic/mirrors.yml'.
[20:56:06] [SEVERE] Starting download of '
http://mirror.technicpack.net/Technic/CHECKSUM.md5', with 3 trie(s) remaining
[20:56:06] [SEVERE] Copying: \temp\file5871256669739097215.tmp to: \launcher\CHECKSUM.md5
[20:56:06] [SEVERE] File Downloaded: \launcher\CHECKSUM.md5
[20:56:06] [SEVERE] [MD5 Mismatch] File '\launcher\technicssp\modpack.yml' has md5 of 'af1a2479a616c75ee134d24a923ac639' instead of '45d306f6d5cfb47c2279c5a138f5be5f'
[20:56:06] [SEVERE] [Info] Downloading 'modpack.yml' from '
http://mirror.technicpack.net/Technic/technicssp/modpack.yml'.
[20:56:07] [SEVERE] [Info] Downloading 'minecraft.yml' from '
http://mirror.technicpack.net/Technic/minecraft.yml'.
[20:56:10] [SEVERE] java.io.IOException: Failed to open file:/C:/Users/Sam/AppData/Roaming/.techniclauncher/technicssp/config/ModLoader.cfg. Error message: Unspecified error
[20:56:10] [SEVERE] at sun.awt.windows.WDesktopPeer.ShellExecute(Unknown Source)
[20:56:10] [SEVERE] at sun.awt.windows.WDesktopPeer.open(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Desktop.open(Unknown Source)
[20:56:10] [SEVERE] at org.spoutcraft.launcher.gui.LoginForm.open(LoginForm.java:620)
[20:56:10] [SEVERE] at org.spoutcraft.launcher.gui.LoginForm.actionPerformed(LoginForm.java:601)
[20:56:10] [SEVERE] at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
[20:56:10] [SEVERE] at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
[20:56:10] [SEVERE] at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
[20:56:10] [SEVERE] at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
[20:56:10] [SEVERE] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Component.processMouseEvent(Unknown Source)
[20:56:10] [SEVERE] at javax.swing.JComponent.processMouseEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Component.processEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Container.processEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Component.dispatchEventImpl(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Container.dispatchEventImpl(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Component.dispatchEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.Window.dispatchEventImpl(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventQueue.access$000(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventQueue$1.run(Unknown Source)
[20:56:10] [SEVERE] at java.security.AccessController.doPrivileged(Native Method)
[20:56:10] [SEVERE] at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventQueue$2.run(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventQueue.dispatchEvent(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
[20:56:10] [SEVERE] at java.awt.EventDispatchThread.run(Unknown Source)
[20:56:20] [SEVERE] [Info] Downloading 'modpack.yml' from '
http://mirror.technicpack.net/Technic/tekkit/modpack.yml'.
[20:56:20] [SEVERE] [Info] Downloading 'minecraft.yml' from '
[20:56:23] [SEVERE] [Info] Downloading 'modpack.yml' from '
http://mirror.technicpack.net/Technic/yogbox/modpack.yml'.
[20:56:23] [SEVERE] [Info] Downloading 'minecraft.yml' from '
[20:56:25] [SEVERE] [MD5 Mismatch] File '\launcher\technicssp\modpack.yml' has md5 of 'af1a2479a616c75ee134d24a923ac639' instead of '45d306f6d5cfb47c2279c5a138f5be5f'
[20:56:25] [SEVERE] [Info] Downloading 'modpack.yml' from '
[21:00:26] [SEVERE] Exiting the Technic Launcher
