Hey guys,
I don't use maps much so there is probably an easy solution to this problem i don't know of...
I have a map with many unique keys but the keys only map to a few distinct values.
E.g.
Key 1 => abc
Key 2 => abc
Key 3 => xyz
Key 4 => abc
Key 5 => abc
Key 6 => xyz
Now if i want to remove a key then i just use map.remove(key) but what do i do if i want to remove all they keys that contain a specific value?
So, using my previous example, i want to remove "abc" so i need to loop through and remove key1, key2, key4 and key5.
I can't see how to loop through a map examining each value so it seems difficult.
Any ideas?
E.g.
Key 1 => abc
Key 2 => abc
Key 3 => xyz
Key 4 => abc
Key 5 => abc
Key 6 => xyz
Any ideas?
