Java not working
5 Feb 2003
I cannot get Java to work in Internet Explorer (I am using the ie7 beta 2). I get a little red cross in the corner. I have tried re-installing Java and have followed the suggestions on the Java website but no luck. Any suggestions?
You're using a beta and expecting everything to work?!? Does it work in IE6 or any other browser?
Found the answer from another forum:
"Confirmed: I experieced exactly the same problem with 1.5.0_05. Rolling back to 1.4.2_05 fixed the problem, but the app I was using needed the later runtime. Only after uninstalling IPV6 by using the "netsh interface ipv6 uninstall" command was 1.5.0_05 restored to it's former glory.
For those interested, I am pretty sure this co-incided with the installation of Microsoft Codename Max, which is based on WinFX and turns on IPV6 by default (it actually needs it). Shame, because Max was kinda cool."
