javascript & flash moive replacement
18 Oct 2002
Southern England
hi all...
I'm currently building an shop for a client (cubecart base) who has now decided that they want to get some flash into the site.
At the moment, when a customer clicks on a thumbnail image javascript does an image replacement and displays a different larger image (named preview). The link is coded:
Code:
<a href="javascript:change_preview_image('{SRC_PROD_LARGE}')">
and this calls the following:
Code:
function change_preview_image(file_name)
    if(file_name.match('alice'))
	document.images['preview'].src = file_name;
This works great. No problems there, and if there is no javascript support then the image won't change which is no issue.
However, the client now wants to have a flash slideshow run instead of a static image being replaced. This is where I am running out of brain power (ok so it's 23:50!)..
How would I go about loading a flash movie instead of a static image?
Any help would be appriciated.
thanks
Rob
