Javascript help please anyone?
18 Jun 2010
Essex
I have the following two code snippets:
Code:
Sun.prototype.kochSegment = function(context, depth, length, angle)
		context.lineWidth = 1;
		if (depth == 0)
			//draw line
				context.strokeStyle = 'white';
				context.moveTo(this.currentX, this.currentY);
				context.lineTo(this.currentX + length*Math.cos(angle),this.currentY + length*Math.sin(angle));
				this.currentX = this.currentX + length*Math.cos(angle);
				this.currentY = this.currentY + length*Math.sin(angle);
		else
			this.kochSegment(context,depth-1, length/3, 0+angle);
			this.kochSegment(context,depth-1, length/3, Math.PI/3+angle);
			this.kochSegment(context,depth-1, length/3, -Math.PI/3+angle);
and
Code:
Sun.prototype.draw = function(context)
		context.save();
		context.scale(this.scale,this.scale);
		context.beginPath();
		context.fillStyle="ffff00";
		if (this.fractalMode != true)
		context.arc(this.getX(),
                this.getY(),
                40,
                0,
                2*Math.PI,
                false
		else
		context.translate(-this.length/2,this.length/3);
		this.currentX = 0;
		this.currentY = 0;
		this.kochSegment(context,this.depth,this.length,0);
		context.translate(Math.cos(Math.PI/3)*this.length,-Math.sin(Math.PI/3)*this.length);
		context.rotate(2*Math.PI/3);
		this.currentX = 0;
		this.currentY = 0;
		this.currentX = 0;
		this.currentY = 0;
		context.closePath();
		context.stroke();
		context.fill();
		context.restore();
Now the problem is as follows:
the following code generates this:
This isn't what I want because it's not filling, I know why, because I'm doing a moveTo, then a lineTo in my kochSegment for every line drawn and fill() only fills after a load of lineTos.
So if I move the moveTo, outside to just before I call the first kochSegment in the second code section I get this:
Any help would be appreciated.
I'm tempted but it's part of my coursework so I don't particularly want it on the internet at the moment.
It's just the fact that:
In the code above I have a load of. moveTo() then lineTo(), then moveTo() then lineTo().
And context.fill() only fills in if it's in the format, moveTo(), lineTo(), lineTo(), lineTo().
So I moved the moveTo() out of the kochSegment function and moved it to just before where it's called for the first time. And it ends up with that strange shape haha.
Fixed it, if anyones interested I can upload the code.
It's a recursive method for drawing a Koch ********* in JS.
