Javascript help - table formatting
20 Jan 2011
I'm wanting to display numbers from a JSON array into a table.
I'm trying to get it to list 2 items then go to a new row but just can't get it to work. Can anyone offer any help? Here's what I have so far.
Code:
<html>
<head>
<title>Telephone List - Classic</title>
<script language="javascript" >
document.writeln("<h2>Telephone List - Classic</h2>");
var telephone = { "contact" : [
      { "Name"  : "Mark", "Number" : 700 },
      { "Name"  : "Luke", "Number" : 400 },
	  { "Name"  : "John", "Number" : 300 },
	  { "Name"  : "Matthew", "Number" : 600 }
var i = 0
document.writeln("<table width='90%' border='1'>");
document.writeln("<tr><td><b>Name</b></td><td><b>Number</b></td><td><b>Name</b></td><td><b>Number</b></td></tr>");
for(i=0;i<telephone.contact.length;i++)
   document.writeln("<tr><td>"+ telephone.contact[i].Name+"</td>");
   document.writeln("<td>"+ telephone.contact[i].Number+"</td>");
   document.writeln("<td>"+ telephone.contact[i].Name+"</td>");
   document.writeln("</tr>");
</script>
</table>
</head>
<body>
</body>
</html>
Im wanting it formatted with a new line every 2 entries.
Code:
Name          Number          Name          Number
Mark          700               Luke            400
John           300              Matthew        600
Any help would be much appreciated.
document.write is never a good thing to use for security reasons, and may even be blocked by default in some browsers. It's better to create DOM elements directly. Can you use jQuery? It's a lot simpler.
Code:
var $table = $('#contacts');
for (var i = 0; i < telephoneData.contact.length; i += 2) {
    var $tr = $('<tr />');
    $tr.append(createCells(i));
    $tr.append(createCells(i + 1));
    $table.append($tr);
function createCells(index) {
    if (telephoneData.contact[index]) {
        var $tdName = $('<td />', { text: telephoneData.contact[index].Name });
        var $tdNumber = $('<td />', { text: telephoneData.contact[index].Number });
        return [$tdName, $tdNumber];
http://jsfiddle.net/2xEL3/
I've also setup the layout of the page in HTML and CSS simply for a better separation of concerns; if the design changes, you don't want to be trawling through JS to amend things.
If you can't use jQuery let me know and I'll give you a native example.
Thank you for your reply. Your solution worked perfectly, however when trying to apply to real data, I think I have jumped in at the deep end. I usually play around with PHP and this is my first time fiddling with JS properly.
Again I appreciate the help.
Code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="content-type" content="text/html; charset=UTF-8">
  <title>Telephone list</title>
  <script type='text/javascript' src='jquery-1.11.1.js'></script>
  <link rel="stylesheet" type="text/css" href="style.css">
<script type='text/javascript'>
$(window).load(function(){
var telephoneData = {
    "contact": [{
        "Name": "Mark",
        "Number": 700
        "Name": "Luke",
        "Number": 400
        "Name": "John",
        "Number": 300
        "Name": "Matthew",
        "Number": 600
    $table.append($tr);
</script>
</head>
<body>
<table border="1" id="contacts">
    <tr>
        <th>Name</th>
        <th>Number</th>
        <th>Name</th>
        <th>Number</th>
    </tr>
</table>
</body>
</html>
Sorry, yes, it is working. I was using that as a stepping stone to a creating a full list with a set of data I already have, hoping I could learn and figure it out myself. It looked like once I had that first bit sorted, all I would have to do is tell it to load the other file instead of having the data in the page, and ask it to sort alphabetically (When I searched how it seemed fairly straight forward)
Basically a colleague had created a dynamic list which pulls data from a file, sorts it alphabetically and is searchable and filters in real time while you search. I was just wanting to take that data file and instead just display all the data in a table in the format from the script above.
I realised that I am in over my head with it and have decided maybe I shouldn't try with something like this first - I'll just make it manually I think.
Assuming the file is JSON formatted, your can use $.ajax to retrieve it in jQuery, then put all the above code in the callback of the AJAX call.
I think its JSON? I really don't know java :confused:
Code:
var contacts1 = [ { name: A, Dr   K',
  number: '42' },
{ name: 'POINT, Miss   R',
  number: '47' },
{ name: 'ANDERSON, Miss   C',
  number: '44' },
{ name: 'PROS, Miss   K',
  number: '74' },
{ name: 'SMITH, Mrs   D',
  number: '47' }, ];
I've just used find and replace in notepad, and copied to excel and just made a table that way. I just had people wanting a printable copy of our filterable list that was all it was for, I just thought it would have been easier to have a second page that made it self from the same data file that people could print for themselves.
It's ok we can just leave it here. Thank you for assisting.
