Javascript < if statement
28 May 2008
got these elements on a webform
Code:
<html:text name="portalSiteForm" property="test.minimumsalary" styleClass="input10" />
<html:text name="portalSiteForm" property="test.maximumsalary" styleClass="input10" />
want to use JScript to check if the value in 'test.minimumsalary' is less than value user will input in 'test.maximumsalary'
If possible I want the valadation to be carried out when the user inputs the value into 'test.maximumsalary' rather than after hitting submit. This is what I tried but not sure if its incorrect or just not functioning on my local copy..
Code:
<SCRIPT TYPE="TEXT/JAVASCRIPT">
// Check salarys
function check() {
  if (#test\\.maximumsalary.value) > (#test\\.minimumsalary.value)  {
    alert ("NO")
</SCRIPT>
adding a onChange() to the 'test.maximumsalary'
Code:
<html:text name="portalSiteForm" property="recruitni.maximumsalary" styleClass="input10" onchange=check() />
should be onclick maybe? Thanks for any help :)
