One of them days today
Can someone show why the following XML:
Doesn't render correctly please.
I'm running this code which seems to 'pop-up' all over the place for traversing XML files.
(Yes I know I'm not getting the attribute "text", I can cover that later, but it's still not rendering the correct child nodes, as if it's omitting the last one per child)
Totally stumped.
Code:
<?xml version="1.0" encoding="us-ascii" ?>
<node text="Top" parentID="0">
<node text="Spirits" parentID="" tag="1">
<node text="Brandy" parentID="1" tag="B">
<node text="Cognac / Armagnac" parentID="B" tag="10">
<node text="Cognac" parentID="10" tag="23" />
<node text="Armagnac" parentID="10" tag="8" />
</node>
<node text="Other Brandy" parentID="B" tag="19">
<node text="Grape Brandy" parentID="19" tag="162">
<node text="Other Grape Brandy" parentID="162" tag="125" />
</node>
<node text="Grape EDV" parentID="19" tag="164">
<node text="Fine (EDV)" parentID="164" tag="92" />
<node text="Grappa" parentID="164" tag="34" />
<node text="Singani" parentID="164" tag="105" />
<node text="Pisco" parentID="164" tag="102" />
<node text="Marc / Lie" parentID="164" tag="100" />
</node>
</node>
</node>
</node>
</node>
Code:
function loadXML(xmlFile)
xmlDoc.async="false";
xmlDoc.onreadystatechange=verify;
xmlDoc.load(xmlFile);
function verify()
if(xmlDoc.readyState!=4)
return false;
function traverse(tree) {
if(tree.hasChildNodes()) {
document.write('<ul><li>');
document.write('<b>'+tree.tagName+' : </b>');
var nodes=tree.childNodes.length;
for(var i=0; i<tree.childNodes.length; i++)
traverse(tree.childNodes(i));
document.write('</li></ul>');
else
document.write(tree.text);
function initTraverse(file)
loadXML(file);
var doc=xmlDoc.documentElement;
traverse(doc);
Totally stumped.
