JavaScript problem
31 Dec 2002
Hi, I am struggling to get the following code to work. I am trying to extract the value from a selected drop down list option item and then using an if statement to compare to a value. I know the two variables get the value ok, as if I use an alert with the variable item in brackets it displays the selected value fine. For some reason I cannot get the if statement to check it. The values in the option items in the list are "1" "2" and "3". "q1" is the id of the select element:
function score()
var list = document.getElementById("q1");
var item = list.options[list.selectedIndex].value;
if (item == 2)
alert("Correct");
else
alert("incorrect");
hope someone can help.
