Javascript puzzle
24 Nov 2002
38.744281°N 104.846806°W
Why on earth doesn't this work....?
I'm sure it is a simple thing....
Code:
<script type="text/javascript">
function reset() {
if (document.form1.Text1.value = "reset") {
var answer = confirm("Reset Database? - Are you sure?")
	if (answer){
		alert("reset")
	else {
		alert("not reset")
else {
</script>
Well for starters you have 3 end braces } when you should have 2.
Code:
function reset() {
if (document.form1.Text1.value = "reset") { <---- this should be == not =
	if (answer){
		alert("reset")
	else {
		alert("not reset")
	}<----- too many
else {
</script>
Works for me if you use ==
Problem must be elsewhere.
proof
Code:
<html>
<head>
<title>x</title>
function reset() {
if (document.form1.Text1.value == "reset") {
	if (answer){
		alert("reset")
	else {
		alert("not reset")
else {
</script>
</head>
<body>
<a href="#" onclick="reset();">test</a>
<form action="" name="form1">
<input type="text" name="Text1"/>
</form>
</body>
</html>
