Javascript - what array to look at
28 Jun 2005
London
Hello
I'm a bit stuck, I'm trying to have a template that will look at a variable and know which array to look at.
Say I had 2 arrays german & french.
var german = new Array();
german[0] = "German1";
german[1] = "German2";
var french= new Array();
I would like to be able to have a variable "market".
So if I set:
var market="german";
And put this in the HTML:
document.write(market[0]);
I would like it to display "German1"
Instead it is treating var market as a string and displaying the first element of the string "G".
I'd appreciate any help on this!
Thanks!
Code:
var market = german;
Lose the quotes ;). With quotes you are saying that market = the string german, rather than copying whatever is in the german variable (the array of data) to it.
Great, that worked and it's awesome BUT..
If I declare that first and then the array I get an undefined error if I put alert(market);
I assume that this is because the variable is the same as the array.
Is there anyway I could have the original variable as german1 then after declaring the array remove the 1 from the variable so it's back to german - thus it working!
Thanks!
Heh yeah, the statement needs the array it's copying the data from to be declared first - otherwise you're saying that var market = <null> which just doesn't work.
