Javoll, noch ein HTPC Build...
How long is your Corsair HX620w PSU? The Prodigy is very tight for over sized PSUs, if its 160mm then it not be a problem. I'm very happy with mine, lots of flexibility with hard disks and cooling. The rubber handle/base which are a little unstable, but not really a problem.
I'd go with the crucial m4 (with bracket) myself.
Maybe consider the asrock z77e just because its a nicer chipset for £15 more, although you'd not be clocking anyway so no big advantage.
It should do, I've the lowest end Llano chip and it handles HD iplayer with no problems. Zacate is a completely different CPU, I tried one for a media player, anything on the GPU was fine, but as soon as you had to use the CPU to decode it just wasn't upto the task for HD content.
iPlayerHD can offload to the GPU, so that'll be what is happening there - you need to try it on some Silverlight content.
