I have a chance to get my hands on one of these power suppliers for 55 quid, so want to get some advice first
Currently I'm running
OCZ ModXStream Pro 600w
quad core 2.66 @ 3.2
XFX 5870
3 HDDs
1xCDROM
Cooling
XSPC Dual 750 (pump)
8 way fan controller running 3x180mm and 5x120mm fans (might be cutting down to 3 120s)
I have also got a LED hub which I intend on running +/- 8 or so single LEDs
3 30" Cathodes and 1 10"
Atm, it seems to handle ok but i think it I am straining it alittle.
Want to be able to use this PSU with my future upgrade as well which will be:
Rampage extreme 3 + i7 930 @ 4.2
Crossfire XFX 5780s
and possibly a second loop so an additional pump+fans.
so... Do you think this PSU will cut it? Also anyone know if it will support the 6pin power on the i7 boards (i think its 6 and not 4)
Cheers!!
XFX 5870
3 HDDs
1xCDROM
Cooling
Crossfire XFX 5780s
Cheers!!
