Hi everyone i wondered if anybody has ideas of what i can do to the front of this case
Im thinking of taking out the 3.5" drives and put a 120/140mm fan in its place.
Or if possible put 3x120 or 3x140mm
but as the pic shows where it is already cut it cant do a lot well i think ?
I have ideas about the inside of the case, such as turning the HDD cage 90 degrees for easy install/extraction of HDD. totally removing the 3.5 bays to aid room for bigger graphics cards.
Install a big exhaust fan on the top.
and also spray it.
and also spray it.
