Most Recent Picture
Hello, this is my first proper post on this site. Ive been modding cases for a few months now and decided to post a log on my CM690 which is a current work in progress.
so far I have done a window mod for it.
Here's the side panel masked off.
Cut And primed
Panel Painted and Acrylic fitted
Now I have my my CM690 for 3 years now, and I love the case, however apart from a the side panel, i have never done anything more to the case, so ive decided now its time to make a few changes to my setup.
Plan Of Attack
1. Moving The Hardware
First thing to do, was to move the hardware over to another case temporarily so that the system was still useable and safe.:salute:
Yes, that hardware is going into the red case... :thup:
My Temporary Power Switch :thup:
Hardware installed and system up and running, And folding away again.
Currently only running with 1 120mm cpu fan, will be installing a few more tomorrow once ive cleaned them up. 100% load temps are between 42C and 47C @ 2912 MHZ (416*7)
2. Case Stipping
Next move was to strip all the tool-less hardware, IO ports, feet and sound dampening, ect from the cm690 chassis.
Getting the Thumbclips for the pci slots out wasn't the most fun activity i've had to do.
Also whilst i had the case apart, i've decided to cut the plastic out of the top panel seen as its restrictive of airflow and blocks fans. The area marked in red will be cut out.
I am also temped to cut the grills out from the top fan slots however i do not know what benefit this would have, however i have seen a lot of CM690 mods in which this has been done so if anyone could inform me of a reason to do it, it would be much appreciated.
Update 1: 14/08/2011
Today i Have managed to sand down the case, and prep it for priming. Just waiting for it to dry out after rubbing it down with some sugar cleaning solution. Should have it primed tonight.
Also, picked up a tin of grey primmer, some Matt black, and clear Lacquer for the case.
Pics to follow tonight. Also started on the side blower, and new holder for the fan from the hard drive cage.
Cut And primed
Plan Of Attack
- Move Hardware to new case
- Strip Down CM690
- Paint Case Internals
- Make Side Blower to help exhaust hot air from psu + GTX460
- Cut grills
- Install Corsair H100/other h20 cooling
- Cable Management
- Transform Internal to external DVD drive
- Install Fan controller
2. Case Stipping
