Hi,
I'm trying to get some syntax highlighting in a java project of mine, but I didn't fancy writing the highlighting engine thing myself. Instead I went on the hunt of a library to use and found the jEdit one.
The problem is that there is an error related to enum's (according to netbeans) in one of the methods. Basically It won't compile with java 1.5
http://skitch.com/jonb/h24d/jbird-alpha-netbeans-ide-6.5
Is anyone able to help me fix this problem, or can they suggest an alternative syntax highlighting library?
Many thanks,
Jon
Code:
* Returns the name of the specified text area action.
* @param listener The action
public static String getActionName(ActionListener listener)
Enumeration enum = getActions();
while(enum.hasMoreElements())
String name = (String)enum.nextElement();
ActionListener _listener = getAction(name);
if(_listener == listener)
return name;
return null;
Many thanks,
Jon
