jewel quest problem pls help !!!!!!!!
Caporegime
1 Jun 2006
Notts
well my friends missus plays this a lot :p and hes getting loads of grief cause her pc will not run it properly .
so hes having to sacrefice his cod game time which is not good :mad::D
everytime she trys to launch game on her pc it says out of range frequency and screen is black.
weve tried all sorts but cant get it to work .you can here the sound but no picture is available.can anyone help pls.
The in-game resolution is set too high, have a look for an .ini file to change it.
Actually, I've got the game myself, I'll have a look...
Resolution, unfortunately is set in the registry as a hex value.
HKEY_CURRENT_USER\Software\Infinate Interactive\Puzzle Quest
start, run, regedit and (being careful not to ruin anything) navigate to that path and adjust the numbers that are resolutions (don't know which ones as I don't have the game). Just a case of right clicking on the correct items and choosing "modify..." to something sensible - e.g. 1024 and 768 or 1280 and 1024
edit: although frequency range sounds more like a refresh rate issue than resolution?
