joining 2 databases SQL
11 Aug 2005
Essex
Hi,
I am trying to write a simple sql script to join to tables together on different databases.
This in it self is normally quite simple
Code:
select * from extractsql1..tenagree
inner join extractsql2..RentTransactions blah blah blah
except that the extract1 database is actually called 630_extract1
when I try and join this table together I get this error
Code:
Line 1: Incorrect syntax near '630'.
Which I believe that is because the DB name starts with a number.
I have no idea why it was set up in this way and renaming the database is the very very last option. Is there any way to get around this?
I can't create a copy of the database as this is a report that is going to get run regularly and the database is updated all the time.
Thanks in advance
Which database manager are you using? I know most will only allow you to connect to (and hence query) one database at a time and you have to do fancy stuff to get round it.
Hi guys,
I am using query analyser
fixed the issue by using square brakets
Code:
select * from [630_extract1].dbo.tenagree
thanks for your help
