** JONSBO-NANZA **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
Today we have a raft of new Jonsbo products hitting the site for pre order. Expecting these will likely land with us around the start of 2026
Looking in more detail, these cases use a mixture of premium materials and depending on the price point, there are a host of unique and high end features.
I have used the build example images for the links below as they really showcase what the new Jonsbo range can offer to a system builder.
The price points are really surprising when you factor in the higher end features such as curved glass panels and LCD screens.
There are a few models here so I have put together a brief overview of each type of new model we are carrying.
Jonsbo D200 Midi-Tower mATX Gaming Case - Available in Black or White​
a small footprint MATX tower with curved tempered glass, decent cooling support and a display readout on the front panel.
Jonsbo D32 PRO - Available in Black or White with Mesh or Tempered Glass Side panel options.​
A versatile and affordable MATX case that is offered in a wide variety of outer panel configurations. This case can hold high performance cooling solutions and bigger GPUs whilst simultaneously offering a small footprint and practical build features. Each case has a windowed and mesh side panel variant.
The PRO versions simply offer a higher level of front panel IO options whereas the STD variants offer a more minimal set of connectivity options and a slightly finer mesh finish.
Jonsbo D32 STD - Available in Black or White with Mesh or Tempered Glass Side panel options.​
Jonsplus X400 ATX Mid-Tower, Tempered Glass - Grey
This one is probably my favourite from the new Jonsbo lines we are carrying. This sits under their more premium focused 'Jonsplus' sub brand. Featuring a modular aluminium frame and a host of configurable panels, the X400 is a strong choice for a higher end system build
Jonsbo TK-4 Midi-Tower - Available in Black, White or Wood Finish​
The TK4 is a dual chamber option that features a narrower depth than a lot of other products in that class. The TK-4 has a host of intelligent design decisions including back connect support, a dual curve one piece TG windowed panel and a plethora of fan mounting locations.
I have had EOL notices from Jonsbo for some popular products.
These are the last units of stock we have on hand. Some lines only have a couple of units of stock left.
If you want one of these cases, it will be the last time we carry them. They are all discounted significantly from MSRP in order to get them gone.
*the discounts may not show on the images right away as below but will be active if you click through to the website
  • SKU: CA-00P-JB
  • EAN: 6970620550404
  • MPN: UMX3 BLACK
Micro-ATX PC case, Compatible with Mini-ITX and Micro-ATX motherboards, Front mounting position for ATX PSUs, Three sides formed from a single aluminium panel, Maximum GPU clearance of 320mm, Acrylic side panel
£97 (incl. VAT)
£60 (incl. VAT)
  • SKU: CA-00Y-JB
  • EAN: 6970620550282
  • MPN: U4 WHITE
Jonsbo U4 outer shell is made from 2.0mm aluminum, full tempered glass side, a innovative structural joining technology given strong structure and good appearance
£76 (incl. VAT)
£45 (incl. VAT)
  • SKU: CA-018-JB
  • EAN: 6970620550008
  • MPN: TR03-A SILVER
Triangular ATX PC case, Steel, aluminium, and tempered glass construction, Supports up to six storage drives, Install up to ten cooling fans, Maximum GPU clearance of 460mm, Supports Mini-ITX to ATX motherboards
£220 (incl. VAT)
£150 (incl. VAT)
  • SKU: CA-01A-JB
  • EAN: 6970620550053
  • MPN: TR03-A BLACK
£220 (incl. VAT)
£150 (incl. VAT)
The sku CAS-JON-06768 was not found
The sku CAS-JON-06767 was not found
  • SKU: CA-00F-JB
  • EAN: 6970620550350
  • MPN: RM3 BLACK
Micro-ATX PC case, Steel, aluminium, and tempered glass construction, Supports up to five storage drives, Mounting points for three cooling fans, Maximum GPU clearance of 310mm, Supports Mini-ITX and Micro-ATX motherboards
£90 (incl. VAT)
£63 (incl. VAT)
  • SKU: CA-02F-JB
  • EAN: 6970620552064
  • MPN: MOD3 mini Grey
Open frame PC case, ARGB lighting, Unique form, USB-C featured on I/O, GPU up to 360mm long, Micro-ATX motherboard
£190 (incl. VAT)
£130 (incl. VAT)
  • SKU: CA-02C-JB
  • EAN: 6970620551944
  • MPN: D40 white
ATX PC Case, 3mm tempered glass panel, ATX PSU, Flexible storage bays, GPU up to 355mm long, Extensive cooling support
£100 (incl. VAT)
£60 (incl. VAT)
The sku CA-02P-JB was not found
  • SKU: CA-00A-JB
  • EAN: 6970620550213
  • MPN: C5 BLACK
Mid-Tower PC case, Steel, aluminium, and tempered glass construction, Supports up to seven storage drives, Install up to four cooling fans, Maximum GPU clearance of 340mm, Supports Mini-ITX to ATX motherboards
£60 (incl. VAT)
£42 (incl. VAT)
  • SKU: CA-004-JB
  • EAN: 6970620550305
  • MPN: A4 SILVER
Mini-ITX PC case, PCIe 3.0 x16 riser cable included, Two tempered glass side panels, Install up to four 120mm fans, Maximum GPU clearance of 325mm, Supports SFX and SFX-L PSUs
£100 (incl. VAT)
£80 (incl. VAT)
  • SKU: CA-002-JB
  • EAN: 6970620550428
  • MPN: A4 Black
£100 (incl. VAT)
£75 (incl. VAT)
I like that D32 Pro without glass, but can't quite tell if that can accommodate two 3.5" hard drives and two 2.5" hard drives at the same time?
Not that I need it, but.....
Unfortunately it is one or the other. If you use the 3.5 mounts then the 2.5 mounts are omitted from use.
This is the factor we see with a lot of MATX cases from all vendors really.
With 3.5 drives being used less frequently, especially in chassis with space constraints, many manufacturers are either not supporting 3.5 drives at all or the mounts are a hybrid with 2.5 mounts also.
the only cases with
Yeah, seen that with the Fractal Pop micro ATX and the NZXT H3.
Was tempted to simply drop an HDD and try the Phanteks M3 XT.
But also tempted to simply swap some case with my lad, and re-use the old Silverstone TJ08Be case.
Just built a 9900X office PC for my father in-law using the D32 Pro Mesh. Super easy, well laid-out case. Bit of a bummer that you can't have front intake fans but I guess that's the price you pay for the size & form factor.
I discussed the case choice with him for ages and what does he immediately do? Sticks the case on the floor with a deep pile carpet = intake fans blocked. Being a mesh case it wasn't completely catastrophic as the exhaust fan created a negative pressure, but stiull, argh!
I think you can 3D Print some risers for the feet.
Edit: Yep they are here: https://makerworld.com/en/models/12...jonsbo-d32-case?from=search#profileId-1228867
had this shared with me this morning. Great video showcasing one of our newer Jonsbo case offerings and a solid build example.
The BO400, BO400CG and X400 are all a fresh take on the aquarium case that has a lot of build flexibility with a stylised outer frame.
  • SKU: CAS-JNP-06055
  • EAN: 6970620554679
  • MPN: BO400
Premium dual-chamber ATX case with aluminum panels, tempered glass, versatile cooling for up to 10 fans, GPU support bracket, and USB-C front I/O for modern builds.
£299 (incl. VAT)
£260 (incl. VAT)
  • SKU: CAS-JON-06872
  • EAN: 6970620555331
  • MPN: BO400CG
Mid-tower PC case, Extensive motherboard compatibility, Supports up to 10 fans, Modular design, Curved glass panel, Aluminium frame
£260 (incl. VAT)
  • SKU: CAS-JON-06781
  • EAN: 6970620555539
  • MPN: X400 GRAY
Mid Tower PC case, Compatible with back-connect motherboards, Houses GPUs up to 427mm, Space for CPU coolers up to 176mm, Accommodates powerful cooling solutions, Reinforced frame
£120 (incl. VAT)
