Hi Gang
We have the new Jonsbo T9 model inbound with stock due to land in the coming weeks.
Featuring a revised PCIe 5.0 cable in the box, the T9 is a flexible and stylish ITX case that goes toe to toe with the best sellers on the market which are still shipping with PCIe 4.0 internal cables.
This is a compact sandwich design which houses a reasonable 310mm length GPU up to three slots wide. With plenty of ventilation, this ITX case has great scope for a compact gaming system or a powerful mini workstation.
The T9 PCIe 4.0 model is in stock too if you don't need the extra bandwidth.
- SKU: CAS-JON-06767
- EAN: 6970620555003
- MPN: T9 BLACK
Space-saving ITX case with elegant design, wooden accents on the underside, graphics cards up to 310 mm with Riser cable 4.0, steel side panel with ventilation slots, suitable for ITX motherboards, CPU cooler up to 78 mm
- SKU: CAS-JON-06768
- EAN: 6970620555010
- MPN: T9 SILVER
Space-saving ITX case with elegant design, wooden accents on the underside, graphics cards up to 310 mm with Riser cable 4.0, steel side panel with ventilation slots, suitable for ITX motherboards, CPU coolers up to 78 mm
