Hi all
I'm up for changing my PC case, I currently have a Corsair Air 540 (which is about 4 years old or so, maybe a bit older). I want to go a little smaller and had my eye on the Lian Li PC 011 Dynamic mid-case (which I can see is very popular). I think that case is slightly deeper than I want (certainly deeper than the Air 540 - Lian Li specs say 445mm the Air 540 is 420mm).
I came across the Jonsbo U5 on OCUK, I love the simple clean look and fits with the measurements I'm looking for, but wondered how good/easy it is to build with and what's the best fan configuration, only found one post in a forum search? Can't believe there aren't more of you using it?!
I'll be putting a Strix Gaming-F Z390 mobo cooled with a Corsair AOI H100 and EVGA Superclocked GTX 1080 GPU in it - not full water cooling.
Thanks
Thanks
