I currently have a Microsoft Sidewinder Force Feedback stick which I've had for years and still works perfectly. It's a gameport (not USB) device.
I've just discovered that apparently there will be no gameport support in Vista which is something I will be moving to sooner or later so I need to consider a USB stick. I'm a bit disapointed really and hate to abandon a perfectly working joystick especially as it was quite expensive when I bought it.
I'd want a stick with an 8 way hat switch, force feedback isn't essential but I quite like it! I presume MS no longer make anything similar as there is nothing on their site. I'm not sure I want to go as far as some of the Saitek/Thrustmaster controllers but may consider them as they aren't quite as expensive as I thought they might. It will be more FS9/FSX that it used with as opposed to combat sims.
Any recomendations?
Any recomendations?
