Joystick recomendations
18 Feb 2007
Looking to get into flight sim games and others that need a joystick. What should I be looking for? Don't really want to spend upwards of £30 can someone fairly decent be had for less than that?
i have a saitek cyborg evo and i find it does the trick :) slight dead zone issues, but all ya have to do it find where the position is in the middle, unplug, then plug back in and its centered again :) what ever position the joystick is in when its connected, it thinks is the center :p
What is that bit that is on the side of the joystick? Does that not get in the way? - Not even sure what it is :S
Your hand rests on it.
There probably isn't a better stick in your price range, the EVO has been great for me the past few years.
Sounds good, it doesn't have the throttle bits like that Saitek Aviator.. are those something that I would miss?
