Well, basically, i have a Jpanel which i can draw on. called SetColourPanel.java
I also have a Jframe to which consists of a north and center panel. The north containing a jbutton which changes the colouring of the lines, called SetColourFrame.java
The problem i'm having is trying to run SetColourFrame.java. I thought if i used
That would add my panel to the center of the panel but it's not.
The errors i'm recieving are..
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: adding a window to a container
If you need to see more code feel free to ask, just i'm not too sure where i've gone wrong here.
Cheers
Code:
public SetColourFrame() {
this.myColourPanel = new SetColourPanel();
this.getContentPane().add(myColourPanel,java.awt.BorderLayout.CENTER);
initComponents();
Cheers
