JPG corruption?
10 May 2004
Sunny Stafford
Apart from a failing hard drive, do you guys know what causes occasional image corruption? It mainly affects JPGs, where the lower half of the image is replaced by a repeating pattern, as pictured below. I've had a few very rare cases of PNGs going pop as well where it will just fail to open.
It doesn't affect any other file types e.g. MP3s. This is across 7 PCs that I've had from 1999 to the present.
yeah I've had similar a few times, usually it's because a few bytes of the file is missing for some reason during transfer.
Can sometimes be caused due to system RAM only being 99% stable instead of 100% or just random failure of the disc.
what are you taking the images with?
I had a issue with images being cut off and it was down to the SD card being faulty and the images being stored on certain parts of the SD card
might be worth considering that if your using a digital camera with a removable SD card
AMD CPU's did at some point have a legit hardware bug that was exposed by jpegs.
Also there was a bug with AMD's video drivers if jpegs were viewed using windows photo viewer.
Going to C:\Program Files\Common Files\ATI Technologies\Multimedia and renaming the DLLs amf-wic-jpeg-decoder64.dll and amf-wic-jpeg-decoder32.dll does work as a temporal solution for now, but I hope AMD will fix their decoders soon.
If 'backup' versions of the jpegs are fine then something is corrupting your data.
