- 2 Nov 2007
Hello all,
Im currently working on a new website and a new drop down menu using this tutorial
So far, this is what i have. It all seems to be working OK so far, but i dont like the fade transition its using. I would prefer something more like on the Nvidia site where there isnt a "fade lag".
I tried to use jQuery's FadeIn transition instead of the current fadeTo - but it just seemed to break the whole menu. So, how do i go about changing the transition effects (and trying some out), simply copying and pasting over the current fadeTo doesnt seem to work?
Thanks for any help
This is the code:
Thanks for any help
This is the code:
Code:
<script type="text/javascript">
$(document).ready(function() {
function megaHoverOver(){
$(this).find(".sub").stop().fadeTo('fast', 1).show();
//Calculate width of all ul's
(function($) {
jQuery.fn.calcSubWidth = function() {
rowWidth = 0;
//Calculate row
$(this).find("ul").each(function() {
rowWidth += $(this).width();
})(jQuery);
if ( $(this).find(".row").length > 0 ) { //If row exists...
var biggestRow = 0;
//Calculate each row
$(this).find(".row").each(function() {
$(this).calcSubWidth();
//Find biggest row
if(rowWidth > biggestRow) {
biggestRow = rowWidth;
//Set width
$(this).find(".sub").css({'width' :biggestRow});
$(this).find(".row:last").css({'margin':'0'});
} else { //If row does not exist...
//Set Width
var o = $(this).find('.sub').offset();
var p = $('#megaMenu').offset();
var pw = document.getElementById('megaMenu').clientWidth;
var tw = rowWidth;
o.left = o.left - p.left;
var tml = (tw + o.left) - pw;
$(this).find(".sub").css({'width' : rowWidth}).css({'margin-left':'-' + tml - 20 + 'px'});
function megaHoverOut(){
$(this).find(".sub").stop().fadeTo('fast', 0, function() {
$(this).css({'margin-left':'0'});
$(this).hide();
var config = {
sensitivity: 2, // number = sensitivity threshold (must be 1 or higher)
interval: 100, // number = milliseconds for onMouseOver polling interval
over: megaHoverOver, // function = onMouseOver callback (REQUIRED)
timeout: 500, // number = milliseconds delay before onMouseOut
out: megaHoverOut // function = onMouseOut callback (REQUIRED)
$("ul#topnav li .sub").css({'opacity':'0'});
$("ul#topnav li").hoverIntent(config);
</script>
