I have been changing my website around and using jquery to achive a dropdown navigation bar and a slide show effect.
However the slide show images appear to be on top of or taking presidance over the dropdown navigation bar and subsequently you cannot access then, I have only tested so far in IE and chrome; IE has a strange issue of not even displaying the dropdown bar sometimes.
To see what I mean visit the page and try the navigation drop down bars * there are only dropdown bars for IT Support and IT Security*, I should also note I have only setup the demo on the home page so far.
The jquery code I am using for the slide show is
The following css is applied to the images
The navigation menu is made up of the following code:
HTML
CSS
It might be a CSS issue with the slideshow images appearijng over the menu
but i cannot work it out and unsure how to fix it.
Thnaks
Code:
div#advert
width:950px;
margin-left:auto;
margin-right:auto;
position:relative;
div#advert img {
position:absolute;
top:0;
left:0;
z-index:8;
HTML
Code:
<div id ="menuback">
<div id="menucontainer">
<ul class="dropdown">
<div class="split"></div>
<li><a href="index.html">Home</a></li>
<li class="top"><a href="about.html">About</a></li>
<li class="top"><a href="itsupport.html">IT Support</a>
<ul class="sub_menu">
<li><a href="contract_support.html">Contract Support</a></li>
<li><a href="managed_service.html">Managed Service</a></li>
<li><a href="callout_support.html">Callout Support</a></li>
<li><a href="it_projects.html">Projects</a></li>
</ul>
</li>
<li class="top"><a href="itsecurity.html">IT Security</a>
<li>
<a href="penetration_testing.html">Penetration Testing</a></li>
<li><a href="security_policies.html">Security Policies</a></li>
<li><a href="endpoint_security.html">Endpoint Security</a></li>
<li><a href="network_security.html">Network Security</a></li>
</ul>
</li>
<li class="top"><a href="ithome.html">Home IT</a></li>
<li class="top"><a href="contact.html">Contacts</a></li>
</ul>
</div>
</div>
CSS
Code:
ul { list-style: none; }
LEVEL ONE
ul.dropdown { position: relative; }
ul.dropdown li {color:white; width:98px; height:26px; font-size: 12px; text-align:center; float: left; zoom: 1;}
ul.dropdown a:hover {display: block; color:white; width:98px; height:22px; padding-top:3px; font-size: 12px; text-align:center; text-decoration:none; background-image:url('gfx/navover.png'); background-repeat:no-repeat;}
ul.dropdown a:active { background-image:url('gfx/navover.png'); background-repeat:no-repeat;}
ul.dropdown li a {display: block; color:white; width:98px; height:22px; padding-top:3px; font-size: 12px; text-align:center; text-decoration:none; }
ul.dropdown li:last-child a { border-right: none; } /* Doesn't work in IE */
ul.dropdown li.hover,
ul.dropdown li:hover { background-image:url('gfx/navover.png'); background-repeat:no-repeat; color: white; position: relative; }
ul.dropdown li.hover a { color: white; }
LEVEL TWO
ul.dropdown ul { width: 200px; height:26px; visibility: hidden; position: absolute; top: 100%; left: 0; }
ul.dropdown ul li { font-weight: normal;background-image:url('gfx/TitleBar.png'); background-repeat:repeat-x; color: white;
float: none; width:200px;}
/* IE 6 & 7 Needs Inline Block */
ul.dropdown ul li a { border-right: none; width: 100%; display: inline-block; }
Thnaks
