jQuery help
1 Feb 2006
I have a menu with a list of li tags and then a hidden subnav menu which is made visible on hover. I can't really post up the code as the markup is generated by a SharePoint control and some javscript functions that I can't identify.
At the moment when I hover over an list item in the navigation bar then its sub-menu becomes visible. On leaving the item, the sub-menu disappears. Is there an easy way to make the appear/disappear to use a gradual fade in/out? I'm aware of the jQuery fadein/out functions but I can't seem to put anything together that works.
I tried using onhover on the <li> item but when I scrolled down to the sub-menu it all disappeared.
Is there a few lines of easy code I can add to use fades?
I think you need something like this:
Code:
$("#myid").hover(
	function () {
		$("#someotherid").fadeIn("fast");
	function () {
		$("#someotherid").fadeOut("fast");
Also be aware of .slideDown(500) & .slideUp(500), they might be better for what you need.
I had something very like the code you posted but if I moved the mouse from #myid down into the submenu then the submenu disappeared due to the fadeOut call.
Will look at slideDown/Up.
Edit: I have got a fade working just as a test but when I move across the menu items quickly the fade doesn't work. It appears as if I have to wait for one event to finish before another can work. Am I missing something obvious here?
If I hover from the main page area to a navigation bar item the fade in will work nicely. If I move quickly between other navigation items the animation will only work unless i wait a few seconds for the animation to finish. Does that make sense?
I haven't seen the stop() function used before - surely it would cut the animation off which wouldn't look good?
This is my code so far but not having any luck in getting it to work:
box1Watcher.isHoveringOver() returns true/false if the mouse is over an item or not.
Code:
    $('.menu-item').hover(function() {
        $('ul.dynamic').stop(true, true).fadeIn();
    }, function() {
    	setTimeout( function(){
        	if ((box1Watcher.isHoveringOver()) || (box2Watcher.isHoveringOver())) {
        		//alert('true');//$('.s4-tn ul.dynamic').css('display', 'block');
        	$('ul.dynamic').stop().fadeOut('fast')
        }, 1000 );
Managed to get this sorted... there was a 1px margin-top setting on the dropdown which kept triggering my mouseout event... one of those simple things you seem you miss so easily.
