jQuery Validate: Date validation when not required
27 Dec 2005
Bristol
I've got an input field for a date that is NOT required, but if filled must be in the correct format.
I've got (with irrelevant bits snipped out):
Code:
$.validator.addMethod("ukDate",
function(value, element) {
return value.match(/^\d\d?\/\d\d?\/\d\d\d\d$/);
"Please enter a date in the format DD/MM/YYYY."
$(document).ready(function() {
var validator = $("#form").validate({
rules: {
ukdate: {
required:false,
ukDate:true,
However submitting when it's blank brings up the error. I'm useless with Regex so how do I add an 'OR blank' to the ukDate function?
This works for me:
PHP:
jQuery.validator.addMethod(
	"dateITA",
		var check = false;
		var re = /^\d{1,2}\/\d{1,2}\/\d{4}$/;
		if( re.test(value)){
			var adata = value.split('/');
			var gg = parseInt(adata[0],10);
			var mm = parseInt(adata[1],10);
			var aaaa = parseInt(adata[2],10);
			var xdata = new Date(aaaa,mm-1,gg);
			if ( ( xdata.getFullYear() == aaaa ) && ( xdata.getMonth () == mm - 1 ) && ( xdata.getDate() == gg ) )
				check = true;
			else
				check = false;
		} else
			check = false;
		return this.optional(element) || check;
	"Please enter a correct date"
PHP:
	rules: {
		ukdate: {
			required: false,
			dateITA: true	// dd/mm/yyyy
dateITA is from the additional-methods.js file: http://ajax.microsoft.com/ajax/jquery.validate/1.7/additional-methods.js
Thanks Pho, but doesn't seem to work fro me. Where exactly do I need to put the dateITA method? Tried replacing jQuery.validator with $.validator as per the previous function but doesn't worth either.
PHP:
<link rel="stylesheet" type="text/css" media="screen" href="/css/jqtransform.css">
<script src="http://code.jquery.com/jquery-latest.js"></script>
<script type="text/javascript" src="/scripts/jquery.jqtransform.js"></script>
<script type="text/javascript">
$(function() {
    $("form.jqtransform").jqTransform();
</script>
  <script type="text/javascript" src="http://dev.jquery.com/view/trunk/plugins/validate/jquery.validate.js"></script>
  <script>
  $.validator.addMethod("dateITA",
        var check = false;
        var re = /^d{1,2}/d{1,2}/d{4}$/;
                check = true;
            else
                check = false;
        } else
            check = false;
    "Please enter a date in the format DD/MM/YYYY"
		rules: {
			title: "required",
			category: "required",
			region: "required",
			regionpreference: "required",
			budget: {
				required: false,
				digits: true,
				maxlength: 11,
			ukdate: {
				required:false,
				dateITA:true,
		messages: {
			title: "Enter a job title",
			category: "Select a category",
			region: "Select a region",
			regionpreference: "Select your region preference",
			budget: "Enter your business's postcode",
			region: "Please select a region",
			budget: {
				digits: "Your budget must be digits only",
				maxlength: "Your budget must be a maximum of 11 digits",
		errorPlacement: function(error, element) {
			if ( element.is(":radio") )
				error.appendTo( element.parent().next().next() );
			else if ( element.is(":checkbox") )
				error.appendTo ( element.next() );
			else
				error.appendTo( element.parent().next() );
  </script>
Hmm.. is it showing anything in the error console?
Can you upload a working (or rather, not working :p) example somewhere so I can take a proper look?
Why not just use a HTML option for each date.
Or do what most sites do and fill the date part with an example when document loads.
