[JS]Copying options between 2 select lists
21 May 2003
Guys, my javascript is pretty dire, could do with a hand here please.
I have the following:
  • an "available" select list with x options
  • an "active" select list with y options
  • a button named "activate selected"
When I click the button I want it to copy the selected option in "available" and append it to the "active" list.
If possible I'd like it to copy multiple selected options. I have prototype available so if that's easier then i'll use it.
Code:
function addOptions() {
   var availableNewsItems = $("avaiableNewsItems");
   // loop here to see whats selected and add them to a temp array?
   // loop through the temp array and insert into active select?
How do I detect if an option is selected using DOM?
just bashed this together for you - it doesn't involve the submit button. if you want to involve the button, let me know and I'll add that for you :)
Code:
<html>
	<head>
		<script type='text/javascript' language='Javascript'>
			function CopyOver(from,dest) {
				var copy = from.cloneNode(true);
				var dest = document.getElementById(dest);
				for (i=0;i<dest.childNodes.length;i++) {
					if (dest.childNodes[i].value == copy.value) {
						return false;
					} else {
						var okToCopy = true;
				if (okToCopy === true) {
					dest.appendChild(copy);
		</script>
	</head>
	<body>
		<select multiple='multiple'>
			<option value='1' onclick='CopyOver(this,"dest")'>copy me!</option>
			<option value='2' onclick='CopyOver(this,"dest")'>copy me!1</option>
			<option value='3' onclick='CopyOver(this,"dest")'>copy me!2</option>
			<option value='4' onclick='CopyOver(this,"dest")'>copy me!3</option>
		</select>
		<select id='dest' multiple='multiple'>
		</select>
	</body>
</html>
Code:
if (node.selected === true)
to check for selected nodes
Thanks, would I be right in thinking that checks for an existing copy?
here's what I've got so far:
Code:
function addOption() {
	var availableNewsItems = $("availableNewsItems");
	var activeNewsItems = $("activeNewsItems");
	var selectedOptions = [];
	// if an option is selected, add it to a temp array
	for(var i = 0; i < availableNewsItems.options.length; i++) {
		if (availableNewsItems.options[i].selected) {
			var clonedOption = availableNewsItems.options[i].cloneNode(true);
			selectedOptions.push(clonedOption);
	// insert the option into the 2nd select
	for (var selectedOption in selectedOptions) {
		activeNewsItems.appendChild(selectedOptions[selectedOption], null);
	return true;
function removeOption() {
	for (var i = activeNewsItems.options.length - 1; i >= 0; i--) {
		if (activeNewsItems.options[i].selected) {
			activeNewsItems.remove(i);
	return true;
function addAllOptions() {
		activeNewsItems.appendChild(clonedOption, null);
	return true;
function removeAllOptions() {
	activeNewsItems.options.length = 0;
	return true;
But i'm getting
"Node cannot be inserted at the specified point in the hierarchy"
errors?? Any ideas?
Here's a screengrab of the interface:
can you post all your code so I can work on it rather than have a guess? ;)
and yeah, it checks to see if the option is already in the destination.
out of curiosity, I've not seen this syntax before...what does it do?
Code:
edit: nm ninja Google powers
Code:
It's typical of a lot of Javascript frameworks, e.g. prototype/jQuery/mootools, and works as a beefed-up element selector akin to the native getElementById.
Ok, it's all working in Firefox, sans the check for existing, still issues in IE -
Javascript:
Code:
	// if an option is selected, insert in 2nd list
			activeNewsItems.appendChild(availableNewsItems.options[i].cloneNode(true));
	return true;
	return true;
	return true;
	return true;
HTML:
Code:
<div id="available" class="column">
	<label>Available</label><br>
	<select name="availableNewsItems[]" id="availableNewsItems" multiple="multiple">
		<option value="4">10CC</option>
		<option value="5">50 Cent</option>
		<option value="12">Akira The Don</option>
		<option value="13">Akon</option>
	</select>
</div>
<div class="column" id="addControls">
	<button type="button" id="addSelected" onclick="addOption();">&gt;</button>
	<button type="button" id="removeSelected" onclick="removeOption();">&lt;</button>
	<button type="button" id="addAll" onclick="addAllOptions();">&gt;&gt;</button>
	<button type="button" id="removeAll" onclick="removeAllOptions();">&lt;&lt;</button>
</div>
<div id="live" class="column">
	<label>Live</label><br>
	<select name="activeNewsItems[]" id="activeNewsItems" multiple="multiple">
	</select>
</div>
<div class="column" id="moveControls">
	<button type="button" id="moveTop">↟</button>
	<button type="button" id="moveUp">↑</button>
	<button type="button" id="moveDown">↓</button>
	<button type="button" id="moveBottom">↡</button>
</div>
ah, if it's not working in IE, I'm afraid I can't help - using Linux at the moment :/ sorry
