I have a JS prompt windows that appears within certain IF statement in PHP and I want the message typed in by the user to be held in a PHP variable so it can be submitted into a database.
The prompt will works so just confused as to how to store it to a PHP variable.
This is the JS code for the prompt box.
Any suggestion would be great, thanks.
Code:
function failComment()
var x;
var comment=prompt("Please enter a comment as to why the test failed!","");
if (comment!=null)
x=comment;
