Jubilee Clips Replacements
7 Feb 2004
North East
At the moment, im using these clips :
Which while good, are a bit unsightly :rolleyes:
I was wondering if anyone has any brand names to look for regarding some nicer looking clips
I hate those nylon clips, and Pi-Thon clips are too expensive.. by a long way :(
About £1 a clip MAX really... but suggestions welcome :D
I prefer the really thin ones, they're like 20p from a motor spares shop.
No leaks with my loop.
ichabod crane said:
what O rings they look nice,
[/QUOTE]
a little on the permanent side tough, dont you think ?
heatshrink is greta if you can get it, and the sizes are all to **** !, i sent away for a sample of 30mm DIAMETRE heatshrink form a HUGE supplier, and it turns out that its 30mm widthor 60mm circumference. :mad:
