Hi all,
have the above type balcony doors (no balcony to go out on per say) but I have the double doors, they are double glazed, however the seals are not that great around the doors.
Basically is there any cheap method to add more of a seal around the door? this is to stop excess wind noise, and dampen the traffic leak that I can hear from nearby dual carrageways? I was thinking some sort of double sided tape that has a thin layer of foam in between.
Or another method?
So I can add this around the seals to dampen and stop noise leak through the door seals?
Or another method?
