jumping mouse problems on hp pavilion dm1
30 Dec 2007
Oxonfordshire
im having a problem with the mouse jumping to where the cursor is sitting when im typing.
laptop is about 3 months old. hp pavilion dm1 1110sa
have installed latest drivers
done full virus cleanup
is there any known problems or fixes to solve this
thanks Ali
already checked and its slready set to hide. apperently its done it since day 1
i cant find any reason why it keeps doing it
seems to do it when typing long sentences.
I have just opened my girlfriends pavillion tx2000 as it was not booting up. I discovered that the gpu overheats too much and the solderballing falls apart so i reheated it and tried to reset the solder which has worked so far, however when i was researching the fault there was another one i discovered, which is what you are complaining of. Basically the mouse kept jumping to the corner of the screen. There is a fix for it too which i was trying to find before i rebuild the thing. Its also how i stumbled on this thread.
try this
