I was hoping that someone might help me.
I've got quite a nice setup at home where the phone line is delivered to a number of CAT5e modules around the home. (Keeping in mind the REN, of course!)
The setup at the master socket is as below - labels appear underneath.
1 - Openreach master socket with vDSL plate for fibre attached
2 - CAT5e cables; terminated at the other end with RJ45 connector, which are plugged into a CAT5e patch panel
3 - phone cables connected to Sky boxes
What I'm unsure of is what the item marked ? is called? It is plugged into the master socket.
The white and blue wires going into the ? are held in by a plastic patch/pressure, which come loose if it is moved around too much. Hence the black electrical tape trying to hold everything in place.
I'd like to replace it with something where I can screw in the blue and white wires... but without knowing what it is called (or what I should be buying), I haven't a clue as what to buy.
I bought a Junction Box from Maplin, but I don't think that it is the right thing.
Any help would be much appreciated. Many thanks!
