Juniper VPN Help
5 Oct 2004
I have a policy based VPN setup between two SSG 140's
It would seem that the connection is dropping every 60 seconds, it comes straight back up but I would rather it didn't drop at all
I am sure it must be a timeout issue or something keeps re-negotiating because it reliably happens every 60 seconds
Can anyone help?
Thanks
does the event log show either p1 or p2 dropping and coming back up?
what happens if you run a continuous ping across the vpn?
do you have bi-directional policies enabled?
can you post your configs?
Hi,
a continuous ping across the VPN drops a couple of packets here and there but not as many as I would expect
Bi directional policies are enabled
I will grab the config for you
