- 28 Oct 2010
- Colchester
hello,
Question 1,
i have the sapphire hd 5850 and in the options you can higher or lower the fan speed at the mo mine is at 50%, could/would if i higher it to 75-100% could it damage my card?. i dont care about the noise.
question 2,
I have Akasa AK-CCX-4002HP Venom CPU Cooler with the fan is set to blow in cool air on the grill, i've just another venom fan, should i set the new fan to blow in or extract? but this fan will only be 5cm away from the extracting fan at the back of thr case or will it be trial n error
Thank you
Question 1,
question 2,
Thank you
.. would you recommend overclocking the gfx on air or not?.
