- 29 Oct 2006
- Cardiff, wales
ok guys... im a bit of a noob to all this. i built my pc back in november, and specs are
Intel core 2 duo E6400 with a Thermaltake freezer 7 pro
Asus P5W DH deluxe mobo
MSI 7900gtx 512mb ddr3
2gb ocz gold RAM
Samsung 250gb hd and black cdrw/dvd combo
NEC dvd writer
Hyper 530w
ok... so.. no 1
in the asus ai booster, it says 28*c for cpu and 38*c for system
in speedfan i get the same
but... in coretemp, it says:
CPU#0: temperature readings
Tjunction 85*c
core#0 39*c
core#1 41*c
is this right.. how come the apparent temp of the cpu in coretemp is much higher than speedfan and the asus program? which is right?
next q.
i have been using the asus ai booster to overclock the pc. only slightly, about 10%. but someone told me before that its not very stable. is it ok to use the program to do it, or do i need to to it manually in the bios? i dont like fiddling with things i dont understand in there. and as the asus ai booster overclock seemed fine, is there much point in fiddling manually?
lastly. i have 2 sets of OCZ 1GB Kit (2x512MB) 240Pin PC2-5400 667MHz Dual Channel DDR 2 Gold GX XTC (i.e. 4x 512mb sticks)
the first set, i put in when i built the pc, in slot 1+3
and the 2nd set, i put in about a week or 2 ago in slot 2+4
now. using cpu-z, it seems that the ram timings are different for the 2 sets.. is this right, and are these the optimum settings? if now, how do i go about changing them to make them quicker or more efficient without mullering the ram and/or pc..
thanks for any help to any of the q's. happy new year too
2gb ocz gold RAM
NEC dvd writer
Hyper 530w
ok... so.. no 1
Tjunction 85*c
core#0 39*c
core#1 41*c
next q.
