- 9 Jun 2006
These may have been answered in the overclocking guides but i may have missed them.
1)Whats the max safe voltage(vcore?) before stuff starts to break for an E6600?
And what about the memory(vdimm?) such as Geil Ultra Low Latency PC2-6400?
2)So far i've learnt that overclocking is about increasing frequency, however sometimes you need to up the voltage a bit to get that increase in frequency. I've read that you need to increase it in the smallest amount possible. My question is how many times do you up the voltage until you should realise that your hardware has reached its limit and increasing it anymore will not make it work at the frequency you want it to? As i wouldn't want to keep upping the voltage hoping to get the desired frequency only to bust my computer
3)What can i do to minimise the chances damaging my copy of windows on the HD as i'd hate to reinstall! I read something like if you reduce the timings of memory it can cut things short and this is when corrupt things can get written onto HD which makes things go wrong. So basically i should be fine as long as i don't touch the memory timings, or at least don't make them tighter (reduce)? Or will the same happen if i increase the timings (loosen)?
4)Whats the max safe temp of an 8800GTS with a stock cooler? Because im thinking of doing a bit of overclocking it. Any dangers that i should be aware of with overclocking graphics other than it overheating?
Any other tips regarding these questions would be nice
Thanks in advance
Thanks in advance
