Just a little bit of help please :D
13 Feb 2016
https://www.overclockers.co.uk/ocuk...gaming-pc-fs-153-og.html#t=a2b6c0d3e3f3h0i0j0
The above is my rig. I'm questioning about whether or not I should upgrade my GPU. The only question I want to ask is, should I be able to upgrade to a 970 or a 980 TI. I'm unsure whether they'll be compatible with my build, such as the wattage on the PSU. Will it definitely be compatible because they are available as pre-selected options? All opinions and help appreciated! ^_^
You have come to the right place but that doesn't say what PSU it comes with and being honest, that is quite pricey and you could do that basket much cheaper but your choice.
I've had the 970 and now own the 980ti. The difference, for me, was night and day. Not sure on the PSU, I'm sure one of the other guys will have an answer for that.
If you have the money, the ti is the way.
600PSU would be fine for any Single GPU, if you have the money for 980Ti go for it, but i see better bang for the buck than these 2 choices, especialy if you still need to get decent accessories like keyboard/mouse/headset/Monitor
I would probably give the 970 a miss at this point in time, if you can afford a 980Ti go for it as it will last you a lot longer then a 970. The other option is to see if ocuk get another batch of Fury Nano's at 300.
