** JUST AINT GOT ENOUGH POWER CAPTAIN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
No idea what kind of graphics card if any will be able to power this beast when gaming, though the point of this monitor is really for professionals not gamers, but still the image quality has to be beyond belief!!!!
Dell UltraSharp UP2715K 27" 5K Widescreen LED Monitor - Midnight Grey @ £1,799.99 inc VAT
Discover amazing 5K clarity on the highest-performance DellTM UltraSharp display, featuring over 14 million pixels, precise, accurate color and amazing acoustics from Harman Kardon® .
Pin-sharp 5120 x 2880 Ultra HD resolution: See four times the content of QHD with 11 million more pixels that create crisp images and breakthrough sharpness. Vivid, accurate and consistent color: With PremierColor, your monitor provides superb color accuracy and 99% AdobeRGB and 100% sRGB coverage. Speakers by Harman Kardon® : Two speakers rated at an impressive 16W deliver crystal-clear, highly detailed stereo sound.
Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K Monitor – UP2715K features an astoundingly vivid 5120x2880 Ultra HD resolution. That’s a dramatic increase in screen clarity, with more than 14 million pixels — or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies.
If you’re a graphics or design professional in the entertainment, film, photography or engineering field, you’ll immediately recognize the benefits of a 5K monitor with Dell PremierColor. Details this incredible allow you to view your work with a whole new level of insight.
Features:
- Consistent, accurate colors: Right out of the box, Dell PremierColor delivers factory-tuned 99% AdobeRGB and 100% sRGB coverage, impressive grayscale tracking and a color calibration factory report certifying that colors are true-to-life and accurate with an extremely small deltaE of less than 2.
- Excellent color depth and color gamut: Enjoy a large range of colors and color detail with a wide color gamut1. High-capacity 12-bit internal processing enables up to 1.07 billion colors, distinguishing low grayscale tones and enabling a tremendous level of detail, even in dark areas.
- Use the Custom Color mode to change color parameters to your exact needs. Tune and tweak onscreen colors by utilizing a wide range of color parameters such as RGBCMY saturation, RGBCMY hue, RGB gain and RGB offset.
- For even greater control and precision calibration, the UP2715K comes with a 12-bit user-accessible 3D LUT (look-up table), which is accessible via the Dell UltraSharp Color Calibration Solution software when used with the optional X-rite iDisplay Pro colorimeter2.
Specification:
- Diagonally Viewable Size: 27" (27-inch wide viewable image size) 68.5cm
- Aspect Ratio: Widescreen (16:9)
- Panel Type, Surface: In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 5120 x 2880 at 60 Hz (Dual DP cable required) 3840 x 2160 at 60Hz (single DP cable required)
- Contrast Ratio: 1000: 1 (typical)
- Dynamic Contrast Ratio : Mega7
- Brightness: 350 cd/m2 (typical) / 50 cd/m2 (min)
- Response Time: 8 ms (gray to gray)
- Viewing Angle: (178° vertical / 178° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100% 1.074 Billion colors (True 10 Bits)
- Pixel Pitch: 0.116 mm Pixel Per Inch (PPI) 218
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Connectivity: 1 Mini DisplayPort, 2 DisplayPort (DP1, DP2), 5 USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream, 1 Media Card Reader
- Warranty: 3yr
Only £1,799.99 inc VAT.
ORDER NOW
