JUST ARRIVED: Coolermaster Silent Pro 80 Plus Gold Certified PSU's
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Coolermaster Silent Pro Gold 600W Power Supply @ £99.99 inc VAT
The Silent Pro Gold series features an entirely new design with several innovative and patented technologies. Cooler Master has created HTT™ (Heat Transfer Technology), a unique “L-shaped” heat-sink designed to vastly improve the airflow inside the power supply, resulting in lower operating temperatures. Another unique feature to the Silent Pro Gold series is the Hybrid Transformer™ which mounts the transformer directly to the heatsink. This makes for a more compact transformer and improves the power efficiency at the same time.
Yet another feature that helps improve the power efficiency is Hyper Path™ which is a “hyper link” between the transformer and the various power conversion components. The “hyper link” results in almost a loss-less transfer of energy which has never been done before. Combine all three of these features and you got one of the most quiet and power efficient power supplies in its category. The entire range offers a power efficiency that exceeds 90 percent at 220V, starting from a load of about 50 percent (model dependant), with some models never dropping below 90 percent. During normal use (up to about 50 percent load), neither model exceeds 21 dBA of fan noise thanks to the low RPM fan design combined with the new heat-sink design.
- 90% efficiency typically
- 80 Plus Gold Certified
- 3-way SLI or CrossFireX Support
- A unique "L-shaped" heatsink to remove heat from the PSU
- Hybrid Transformer: Unique design that combines heat-sink with transformer
- Flat modularised cables provide easy cable management leads to better airflow
- Compliance with the latest ATX V2.3 standard
- Operation with intelligent fan speed control
- High reliability (MTBF > 100,000 hours)
- Double Layer EMI filter retains noise and to avoid affect to users
- Integrating active PFC with PWN combo controller while increase efficiency
- Multiple protection design (OVP/UVP/OPP/OTP/SCP/OCP)
- Japanese made capacitors
- Single +12V rail up to 98A
- Five year warranty
Only £99.99 inc VAT.
ORDER NOW
Coolermaster Silent Pro Gold 700W Power Supply @ £114.99 inc VAT
Only £114.99 inc VAT.
ORDER NOW
Coolermaster Silent Pro Gold 800W Power Supply @ £128.99 inc VAT
Only £128.99 inc VAT.
ORDER NOW
Coolermaster Silent Pro Gold 1000W Power Supply @ £157.99 inc VAT
- Quad SLI or CrossFireX
Only £157.99 inc VAT.
ORDER NOW
Coolermaster Silent Pro Gold 1200W Power Supply @ £189.99 inc VAT
Only £189.99 inc VAT.
ORDER NOW
This look like some very good PSUs.CM has really stepped up to the game in the last 1 and a half year with their PSU lineups.
not sure but i wished that all psu had a picture of the front and back to make it far easier to know if the psu are modular i.e. has seperate cables for better airflow. as i have a corsair 650tx, and have a cable that i won't use at the moment, and for obvious reason i don`t want to cut it off lol.
i like the line up... seems everybody is upping their game in the recession/recovery
you can always go to review websites for that though although I agree having everything in one place will be most convenient.
yeah that is true, i thought that my psu would be modular, but i was happy with it, but with space been a premium in an antec 902 a modular psu would be more benifical with a ssd at the bottom of the case (there are screws for a ssd to be put there). i just like to make sure that the case is a airflowable as possible. one less cable that isn`t doing anything is a handy thing to have.
