Looks good but sounds crap on my telly. I was wondering about buying some speakers for it, but not sure what would be compatible. Nothing too fancy and stereo would be good enough. Any suggestions as to what I need?
If you take a look around you will find the Yamaha YAS152 for £130 ( its worth about £200 ) quite highly rated and does have " virtual surround " even though you said surround isnt a priority still nice to have
could also use bluetooth with that bar but as you mentioned id recommend a optical cable anyway due to the chance of disturbance but it's just something the OP may want to consider
