Just bought Ryzen 7 3700X, cooling question
16 May 2012
Hi,
Just bought me a 3700X and am concerned about the temps. I am idling 40C to 50C, and full load 70C-80C. I am using the wraith cooler that came with it.
Any advise regarding getting temps down?
Those temps are fine. What are you worried about?
If you really want idle temps lower, change the fan profile to run faster at lower temps.
Thanks for feedback. Came from an i5 6600k running at 30C to 50C so seemed a bit high.
the thing with most modern hardware is they have better boosting algorithms. Nvidia GPU's and AMD CPU's generally have a thermal limit, so if you are under that it will run faster. AMD CPU's, especially the X models have precision boost which is a max boost speed (single thread) of 4.4ghz on the 3700x, it will go all the way to 80c to try to reach that.
